Ewelink Zigbee Door Window Sensor Contact Security Burglar Door Sensor Alarm Magnetic Door Sensor Works with Alexa Alice
Hub Required: Zigbee Hub is required. Without Zigbee Hub, this zigbee door sensor does not work. Please search B0BRZZBX6Y or B0C85RNQXF for the Hub
This door and window sensor alarm is an excellent security addition to any contact structure: garage doors, skylights, safes, etc. Get real-time alerts at the exact mo..
The sensor gives you the possibility to create a scene linkage of ZigBee and Wi-Fi devices. You can set a scene so that your hallway lights up immediately when the doo..
3-month history records check
The door/window opening and closing status are synced to your phone, no more looking back to see if the door/window is closed
Hub Required: Zigbee Hub is required. Without Zigbee Hub, this zigbee door sensor does not work. Please search B0BRZZBX6Y or B0C85RNQXF for the Hub.
This door and window sensor alarm is an excellent security addition to any contact structure: garage doors, skylights, safes, etc. Get real-time alerts at the exact moment you have unwanted guests, runaway children, open safes or escaped pets.
The sensor gives you the possibility to create a scene linkage of ZigBee and Wi-Fi devices. You can set a scene so that your hallway lights up immediately when the door is opened.
3-month history records check.
The door/window opening and closing status are synced to your phone, no more looking back to see if the door/window is closed.
