Ewelink Smart Zigbee Temperature Humidity Sensor App Control Indoor Thermometer Monitor Home Automation Works with Alexa Google
EWelink Smart Zigbee Temperature Humidity Sensor App Control Indoor Thermometer Monitor Home Automation Works With Alexa Google
Product name : Zigbee temperature & humidity sensor
Battery : CR2450 (Included)
Wireless : zigbee 3.0
Temperature resolution : 0.1 C
Humidity Resolution: 3%
【Support Zigbee 2mqtt / Home Assistant】
Note :The zigbee sensor must be used with eWeLink zigbee gateway. Not supported Tuya/Smart Life.
If you need to connect to a third-part smart device, please ensure that your third-party device has a built-in gateway, otherwise it may not be able to be added;
【Simple Design & Easy Installation】It's a battery-operated sensor with low-battery notification on your mobile, adopts adhesive tape on the bottom to easily install it in any corner of your house , as the living room, baby room, bedroom, greenhouse, reptiles terrarium, equipment cabinet to monitor temperature and humidity remotely.Excellux global store
High accuracy built-in Swiss-made sensor ensures accurate measurement of room temperature and humidity, the temperature is accurate up to ±0.2℃ while the humidity is ±2%RH, and always gives you the latest changes in the environment. which all readings can be checked on eWeLink APP
【Smart Scene To Trigger Devices or Alerts 】You can set a condition in the smart scene that is the fan is turn on/off when the temperature reaches the limit value, or the dehumidifier in your room starts working once the humidity is over higher. You can set a smart scene to trigger alerts through events like high/low temperature, high/low humidity conditions and more. Excellux global store
【Support other third-part voice assistant 】 You can use one Ewelink gateway to add devices on ewelink app first ,then bind the device with yandex alice , alexa ,google assistant ,or smartthings,then use voice control to ask the temperature and humidity . Excellux global store
【Sharing Control】Simply share the sensor to your family on EweLink APP and they can directly check this temperature and humidity on their mobile phones without pairing it. Excellux global store
