Ewelink Smart Home Zigbee Temperature and Humidity Sensor Indoor Hygrometer Thermometer Work with Alexa Google Home Assistant
eWeLink Smart Home Zigbee Temperature And Humidity Sensor Indoor Hygrometer Thermometer Work With Alexa Google Home Assistant
ZigBee Version:( ZigBee Gateway Hub is required)
Note: the ZigBee3.0 Version Sensor can't work alonely,it need eWeLink ZigBee3.0 Gateway to work together.
Operating voltage: 3V
Battery model: 2XLR03AAA battery (not included)
Static current: ∠ 10uA
Alarm current: ≤ 15mA
Low voltage and undervoltage: ≤ 2.2V
Detection temperature: -10 ℃~55 ℃
Detection humidity: 0-99% RH
Temperature Accuracy: ±1
Humidity Measure Range: 0% RH~99% RH
Humidity Accuracy: ±5% RH
Wireless: Zigbee 3.0(eWeLink Zigbee hub )
Zigbee working frequency:2.4GHz-2.484GHz
