Ewelink Smart Home Wireless Door and Window Sensor - Simple and Convenient Zigbee Door Magnetic Detector
EWelink Smart Home Wireless Door and Window Sensor ZigBee Door Magnetic Detector Compatible with SONOFF Wi-Fi Series
1. With an exquisite and fashionable appearance, it can easily blend into various environments.
2. Supports DIY design, with rich scenarios.
3. Intelligent linkage, tool-free installation.
4. Anti-tampering design for professional security fields.
5. Equipped with low-voltage monitoring and prompt function.
6. Transmits data signals wirelessly.
7. Ultra-low power consumption, long battery life.
8. Sends online reports to the host at regular intervals.
Product dimensions: Main unit 26.5X52.5X13.5mm, Sub-unit 12.5X25.5X13.5mm
Color box dimensions: 45*12*15mm
Packing quantity: 200 pieces per box
Outer box dimensions: 475mm*340mm*310mm
Net weight of product: 45g
Gross weight of product: 50g
Gross weight of outer box: 11kg
Product list: Door magnetic sensor * 1, Instruction manual * 1
Note: The product needs to be used in conjunction with a Zigbee gateway and cannot be used independently.
