Smart Home Integration: Seamless integration with voice control systems like for Amazon Alexa and for Google Assistant allows you to manage your home's temperature with simple voice commands.
Remote Access: Control and monitor your home's temperature from anywhere with the TUYA app. This feature is perfect for adjusting your home's temperature before you arrive, ensuring you always have optimal comfort.
Advanced Sensor Technology: This thermostat features precise temperature sensors to maintain exactly the temperature you want, providing a comfortable and consistent environment.
Energy Efficiency: Designed to optimize your home's energy use, this thermostat maintains efficient temperature levels when needed, significantly reducing your energy bills.
Easy Installation: This user-friendly device can be easily installed without the help of a professional, making it a convenient addition to your smart home setup.
Input voltage: AC85-250V 50/60Hz
Output voltage: AC85-250V 50/60Hz
Max.Current: 16A Max.load: 3000W (Resistive)
Wireless: Zigbee
Working temperature: -20℃-80℃
Working humidity: 80%
Color: As shown
Material: plastic
Package Contents:
2 x Smart Switch
2 x Temperature Humidity Sensor(2M)
Wireless: Zigbee
Color: As shown
Material: plastic
Package Contents:
2 x Smart Switch
