8 Sensors already found their owners
See the difference
Ezlo Other Brands
Local Automation
Yes No
Works Offline
Yes No
Multi-Device Automations
Yes Limited
No Subscriptions
Yes No
Rechargeable Door/Window SensorCentralite · Model CLZ-3371-C
Stop a $5,000+ burglary
before it happens
$17.95
Bundle DealsIn Stock
1 pack
$17.95
SAVE $8.90
3 packs
$44.95
SAVE $18.80
5 packs
$70.95
  • Effortless Device Control
  • Voice Control via an application
  • Connectivity with Multiple Radio Frequencies and Devices
  • Seamless Automation with MeshBots via MiOS
Model Number
CLZ-3371-C
Battery Specifications
3.7V 500 mAh Micro-USB Charging Port
Operating temperature
14°F – 120°F
Operating humidity
10% – 90% RH (no condensation)
Environment
Indoor use only — keep away from water and direct sunlight
Wireless Connectivity
ZigBee 3.0
Compatibility
Pair with Ezlo hubs or any compatible Zigbee hub
Installation
Mount on door or window, align magnet with the sensor at no more than ½ inch away
FCCCERoHSZigbeeULWEEE
Centralite Door/Window Entry Sensor — device overview
Built-In Rechargeable Battery: Charge only with a standard 5V Micro-USB charger. Do not puncture, disassemble, or expose the device to fire or extreme heat
Looking for the full installation manual? A detailed step-by-step setup guide for the Centralite Door/Window Entry Sensor (CLZ-3371-C) is available in our Support Center.
Open the Installation Manual
with Rechargeable Battery
Enhances home security through magnetic open/close detection, offering real-time alerts via the MiOS app and seamless integration with Home Assistant for powerful smart home automation
Door & Window Security
Detects the opening and closing of doors and windows using a magnetic alignment setup for effortless home monitoring
Smart Home Automation
Uses Zigbee 3.0 connectivity to work seamlessly with smart hubs, triggering custom automated scenarios based on door/window events
MiOS App Integration
Allows remote monitoring and sends instant real-time alerts directly to your iOS or Android device via an easy-to-use interface
Home Assistant Ready
Offers deep integration with Home Assistant for complex, advanced automations across your smart home ecosystem
Centralite Door/Window Entry Sensor in a modern home
Centralite Door/Window Entry Sensor with Rechargeable Battery
The CLZ-3371-C Centralite Door/Window Entry Sensor detects the opening and closing of doors and windows and works in conjunction with other devices and smart home hubs which enables smart home automation and app alerts. Ensure the door magnet is located on the side of the alignment mark
Detects Openings and Closings
Accurately monitors doors and windows
Enables automation and app alerts for enhanced security
Easy Pairing
Pairs with the MiOS mobile app and other Zigbee hubs
Zigbee 3.0 Connectivity
Integrates seamlessly with Zigbee-compatible smart home hubs
Includes a 3.7V 500 mAh Micro-USB charging port
Compact Design
Discreet and easy to install on doors or windows
Works With Your Smart Home
The Centralite CLZ-3371-C is a Zigbee 3.0 certified sensor — it plugs straight into the smart home you already have
Home Assistant ReadyIntegrates via any Zigbee coordinator for advanced local automations and complete control
Zigbee 3.0 CertifiedPairs with Ezlo hubs and hundreds of certified Zigbee controllers and devices
MiOS App ControlPair, configure, and get instant motion alerts from your iPhone or Android in minutes
Instant Notifications Instant Notifications
Stay informed about any doors or windows left open by mistake. The Centralite Door/Window Entry Sensor with Rechargeable Battery sends real-time alerts directly to your smartphone
Everything Under Control Everything Under Control
Protect your medicine cabinet, toolbox, or any storage containing hazardous items. If they are opened, Ezlo app will notify you instantly
Automatic Light Control Automatic Light Control
The Centralite Door/Window Entry Sensor with Rechargeable Battery is ideal for spaces where lights need to turn off when a door closes. After a set period of time, it will automatically switch the lights off
Frequently Asked Questions
Q: Do I need a hub to use this sensor?
A: Yes. The CLZ-3371-C is a Zigbee 3.0 device, so it needs a Zigbee-compatible hub. It pairs seamlessly with Ezlo hubs (like Ezlo Plus) and other major Zigbee controllers.
Q: Is it compatible with Home Assistant?
A: Yes. As a standard Zigbee 3.0 sensor it works with Home Assistant through any supported Zigbee coordinator, enabling advanced local automations and full control of your smart home ecosystem.
Q: How do I charge the sensor?
A: The sensor has a built-in 3.7V 500 mAh rechargeable battery with a standard Micro-USB charging port — no battery replacements needed. Just plug it into any 5V USB charger.
Q: How do I install it on a door or window?
A: Mount the sensor on the frame and the magnet on the moving part using the included adhesive, keeping them within ½ inch of each other when closed. Make sure the magnet sits on the side of the alignment mark.
Q: Will my automations work if the internet goes down?
A: Yes. With an Ezlo hub your door/window-triggered automations run locally, so scenes like turning on lights keep working even during an internet outage. Only remote notifications require connectivity.
Q: How is my data and privacy protected?
A: We prioritize data sovereignty. Ezlo devices utilize a US-Based Cloud — your data remains secure and is hosted entirely on compliant servers within the United States.
A: We are here to help! For any additional questions or technical assistance, please contact our customer care team at 866-966-2272 or email us at support@ezlo.com.
Download on App Store App Store QR
Get it on Google Play Google Play QR
Frequently Bought Together
Ezlo Plus Smart
Home Hub
Ezlo Plus Smart
Home Hub
$ 179.95
Shop now ›
Ezlo Smart Z-Wave LED Bulb
$ 10.00
Shop now ›
Ezlo Smart Doorbell Camera
$ 179.97
Shop now ›
Trusted Around the World
What's New at Ezlo
New this season: Ezlo Sense health-aware sensing, Centralite Zigbee sensors, Frankever Wi-Fi switches and dimmers, and the Ezlo Water Valve Kits
