SENSOR
Philio 4in1 Multisensor (PIR, Door Window, Temperature & Light)
Regular price $44.95
Regular price $44.95 Sale price
817 in stock
Philio 4-in-1 Slim Z-Wave Multisensor
The Philio 4-in-1 Slim Z-Wave Multisensor is a compact, Z-Wave Plus-enabled device combining four key sensors—motion, door/window contact, light, and temperature. It offers a comprehensive solution for security and environmental automation in smart homes. Key features include motion detection (PIR sensor) with a 10-meter range, a sensor to monitor doors or windows, brightness measurement up to 500 lux, and temperature tracking from -10°C to 70°C. These functions work together to provide a comprehensive monitoring solution for enhanced home automation. The sensor also includes tamper and low-battery alerts, ensuring continuous, reliable performance. With a long-lasting lithium battery, this device seamlessly integrates with major Z-Wave controllers.
The Philio 4-in-1 Slim Multisensor is a compact,
Z-Wave Plus-enabled device combining four key sensors—motion, door/window contact, light, and temperature. It connects seamlessly to Z-Wave Plus hubs, enabling integration into smart home setups. This multisensor offers a comprehensive solution for security and environmental automation in smart homes. It works with EzloPlus, HomeAssistant, SmartThings, and other Z-Wave Hubs.
  • Remote Control Anywhere: Control your home's security and environment from any location using your smartphone or tablet, thanks to Z-Wave connectivity.
  • Motion Detection (PIR Sensor): Detects movement within a 10-meter range, ideal for security and occupancy sensing.
  • Door/Window Monitoring: Tracks the open/close status of doors or windows, enhancing home security.
  • Light Sensor: Measures ambient light levels up to 500 lux, allowing for automated lighting adjustments.
  • Temperature Sensor: Monitors temperature from -10°C to 70°C, helping maintain comfortable and energy-efficient environments.
  • Tamper and Low-Battery Alerts: Alerts users to tampering attempts and low battery levels, ensuring consistent monitoring.
  • Simple Installation: Very easy to install.
  • Z-Wave Connectivity: Operates on Z-Wave (908.42MHz). Some models operate on EU 868.4 ~ 869.85 MHz, JP 922.5 ~ 926.3 MHz, AU 921.42 MHz, or Israel 916.0 MHz.
  • Wide Compatibility: Works with EzloPlus, HomeAssistant, SmartThings, Homey, Hubitat, Aeotec, and other third-party Z-Wave hubs.
  • SKU:
    PHL-PST02-A-US
  • UPC:
    850010803104
  • Protocol:
    Z-Wave (908.42MHz)
  • Operating Voltage:
    3.0 V by CR123A
  • Standby Current
(Sleep Mode):
    8.8uA
  • MCU Wake Up Current:
    25 mA
  • Low Battery Voltage:
    2.6 V
  • Communication Distance:
    Min. 40M indoor, Min. 100M outdoor
  • Battery:
    CR123A 1700 mA
  • Battery Life:
    Up to 2 years (expected life of up to 3.5 years guaranteed by a 1700mAh CR123A Lithium battery)
  • Detector Dimension:
    96(L) x 28(W) x 23(H) mm
  • Detector Weight:
    40 g
