Managing home has never been easier
The point of a smart home? Simple. To make home control easier while increasing the convenience, security, and efficiency of your living space.
Managing Your Home Has Never Been Easier
Customizable branded software ​across all customer touchpoints​
Access to a white-labeled application and deployed for multiple use-cases. Easily go to market with the intuitive interface and end-to-end experience your customers expect. Want to build your own app? You can use our cloud and hardware to facilitate the experience.
Integration with all smart devices​
All smart devices and applications are easily connected in one centralized solution. Out of the box integrations allow for auto-discovery of new and existing devices for easy set-up.
All of the hardware you need​​
Build the perfect smart home system.
Customize a smart security system with home automation that lets you check in on your home, answer the door, and adjust lighting and temperature from anywhere. From cameras to smart locks and sensors, our experts will help you customize a smart home system that’s perfect for you.
Popular Smart Home and Smart Security Kits
A home automation system where everything’s connected
EZ Secure Essentials
All of the essential security components needed to get started and grow as you go!
EZ Secure Environmental​
Get added security and protect your home from damage caused by heat and humidity, with with water leak, and temperature and humidity sensors.
EZ Secure Video​
A security kit with extra video surveillance so you have an eye on everything.
Meet the Ezlo Family of Devices
Performing feats that are nothing short of miraculous.
Security
Keep an eye on the things that
matter most.
Smart Accessories
Make your home smarter and
confortable
Smart Kits
matter most.
FAQs
What is a smart home?
A smart home is a residence that uses internetconnected devices to enable its inhabitants to remotely control and automate various aspects of the home. Smart homes can range from simply connecting a few devices such as lights, locks, and thermostats, to a fullyintegrated system with sensors, voice control, and more. Smart homes are designed to not only make life easier, but also to save energy and increase security.
How to make your home smart?
  1. Get a Smart Home Hub: Smart home hubs act as a central control system for all your home automation devices, allowing them to communicate with each other.
  2. Install Smart Lighting: Smart lighting systems can be used to control and automate lights, dimmers, and other lighting fixtures from a centralized location.
  3. Install Smart Thermostats: Smart thermostats can be used to control temperature and energy usage in your home.
  4. Install Smart Security Systems: Smart security systems can be used to monitor and respond to security threats, such as burglaries, fire, and carbon monoxide.
  5. Install Smart Appliances: Smart appliances can be used to monitor and control appliances such as ovens, washing machines, and dryers.
  6. Install a Doorbell Camera:   Doorbell cameras can be used to monitor the entrance to your home. They have a wide-angle lens that allows you to see who is at your door from inside the home. Doorbell cameras can also be used to record video of anyone who approaches your door. This can be used for home security, as well as for seeing who is at the door without having to open it. Doorbell cameras also typically come with two-way audio, so you can communicate with visitors even when you are not home.
What is home automation?
Home automation is the use of technology to control and automate the different systems and devices in your home. This includes appliances, lighting, security systems, heating and cooling, and more. Home automation allows you to control these systems remotely and automate them to run on a schedule, making your home more efficient and secure. Home automation can also be used to monitor energy usage, alert you to potential hazards, and provide convenience and comfort.
What are the benefits of home automation?
  1. Increased Home Security: Automation systems can be used to monitor and respond to security threats, such as burglaries, fire, and carbon monoxide.
  2. Improved Energy Efficiency: Automation can be used to control lights, thermostats, and other devices to reduce energy consumption and save on utility bills.
  3. Convenience and Comfort: Automation can be used to control devices such as lights, shades, blinds, and appliances from a centralized location.
  4. Remote Access and Control: Automation systems can be programmed to be accessed and controlled remotely. This is especially useful for controlling the home environment when away from home.
  5. Automated Schedules: Automation systems can be programmed to run automated schedules, such as turning on lights at sunset or turning off appliances after a period of time. This can help save energy and increase convenience.
  6. Enhanced Entertainment: Automation can be used to control audio and video systems, allowing users to easily access and control their entertainment systems.
How does smart home automation work?
Smart home automation works by connecting devices and systems in your home to a central control system. This system is used to monitor, control, and automate your home. It can be programmed to respond to certain triggers, such as motion sensors, voice commands, and timers. The system can then send commands to connected devices to turn on lights, adjust thermostats, lock doors, and more. Smart home automation can also be used to monitor energy usage, alert you to potential hazards, and provide convenience and comfort.
What are the best home automation devices?
Some of the best home automation devices include:
  • A smart thermostat.
  • A doorbell camera.
  • Indoor and outdoor security cameras.
  • Smart locks.
  • Glass break sensors.
  • Smart lighting.
Learn more about the best home automation devices.
Latest from Ezlo
Vidoo signup and login Option 1: Vidoo App Login Step 1.1 Click on Vidoo app icon to run the app. Step 1.2 You may asked
Installation Step 1: Run installer Open download folder and run installer. You may asked to enter password for current user to give super user privileges.
Need Additional Help?
From initial setup to expanding your system, Ezlo Customer Care is here to help, every step of the way.
Tell us about your device
Soultions
Products
Ezlo PlugHub
Ezlo Plus
Ezlo Secure
InstaVue Cameras
Security Sensors
Water Shut Off Valve
Climate Control
Lighting
Secure Essentials
Secure Essentials+
Secure Video
Products
Solutions
Support
Explore
MiOS Login
For Ezlo Protect
For Distributors
For Ezlo Partners
Products
Smart Homes Hub
Ezlo PlugHub
Ezlo Plus
Ezlo Secure
Security Addons
InstaVue Cameras
Security Sensors
Accessories
Climate Control
Lighting
Kits
Secure Essentials
Secure Essentials+
Secure Video
Ezlo PlugHub
Ezlo Plus
Ezlo Secure
InstaVue Cameras
Security Sensors
Climate Control
Lighting
Secure Essentials
Secure Essentials+
Secure Video
chatsimple
