Time to replace your light switch with its smarter version
Turn your lights on and off remotely via the app
Automatize light behavior according to your habits
See the status of your lights on the screen of your phone
Why use a Smart In-Wall Switch
Turn off your lights remotely if you forgot to do this when leaving your home
Set your lights to turn on and off according to a schedule to imitate home presence when you’re away
Learn when your kids go to sleep and wake up at night with notifications and logs
eZLO works great with Alexa, so you can turn your lights on and off using voice commands
Have other smart devices?
Set more rules for your home using the eZLO hub:
Sensor
Bulbs
Conditioners
Outlets
Garage gates
Siren
Cameras
  • FCC, ETL and Z-Wave Plus certified
  • Over-the-air firmware updates
  • Z-Wave coverage: up to 40 meters
  • Inbuilt overcurrent and surge rotection
  • LED indicator shows the working status
requires Neutral, Line and Traveler wiring connections to work
requires a Z-Wave hub (like the eZLO hub ) to be controlled remotely
Z-Wave frequency
908.42MHz (US)
Size
Height: 104 mm
Width: 55 mm
Depth: 50 mm
Power Supply
120V +/-10%, 60Hz Power consumption: less than 1W
Power output
1800W
Supports
one external switch to control the same lights
