An outlet that you can also control remotely
Why use smart switch
Power switch on/off appliance
Real time energy monitoring
Inbuilt surge and overcurrent protection
Monitoring power consumption
How It Works
  1. Download the application and set up your eZLO account.
  2. Plug the Plug in an electrical outlet.
  3. Connect the Plug to your Wi-Fi network via the application.
  4. Done! Now you can control your device with your eZLO app.
    *for detailed step-by-step instructions see the manual
Enhance it with the eZLO app
You can use the eZLO hub to create smart rules and launch them with the eZLO app:
Having an AC unit controlled with a smartphone, you can cool your place BEFORE you arrive at home, not after.
With your smartphone always at hand, simply open the eZLO app and turn your stereo system on to listen to your favorite tune.
The TV your kids are watching in another room is too loud? Turn down the volume without shouting and asking them.
  • FCC, CE and Z-Wave Plus certified
  • IR coverage: up to 12 meters indoor
  • Over-the-air firmware updates
  • Z-Wave coverage: up to 40 meters
  • Cloud database of the infrared codes
Z-Wave frequency
868.42MHz (Europe)
908.42MHz (US)
921.42MHz (Australia)
Size
Height: 22 mm
Width: 85 mm
Depth: 85 mm
Powered by
5V/1A Micro USB Adapter
Working current
~60 mA
Standby current
~35 mA
Installation options
table and wall mounting
