eZLO Hub
The heart of your smart home
The eZLO Hub functions as the heart of your smart home by converting smart home appliances into a single, centralized network using the Z-Wave network.
HOW IT WORKS
HOW IT WORKS
Start communicating with your devices
The Hub opens the lines of connectivity and communication between you and your devices, allowing you to connect up to 255 devices from the ever-growing list of 1700 compatible devices to choose from. It is 100% wireless, meaning you can center the Hub from anywhere in your home and remotely control your connected devices to monitor security, energy consumption, lighting, heating and HVAC, and much more.
The LOW COST OPTION FOR your smart home AUTOMATION
The eZLO Hub offers a low-cost option to tap into the smart home automation technological convenience by allowing you to build a fully connected home automation network based on your device preferences. With a growing list of compatible products, the possibilities are endless for the most customizable automation network on the market.
eZLO APP - ACCESS YOUR HOME REMOTELY
Access to your home from anywhere in the world
The eZLO Hub also wirelessly connects to the eZLO web and smart phone apps, giving you control access of your home from anywhere in the world, no matter the hour. The Hub will work even if your home experiences a power outage, so you can rest-assured that your home is monitored no matter the circumstance.
One Device, Endless Possibilities
The starting point for your automated home
With hundreds of Z-Wave devices supported, the eZLO hub can turn most of your smart home appliances into a single network. The web and mobile apps allow you to manage and keep an eye on your home from anywhere in the world. With eZLO, you to do all kinds of stuff with your devices, even create smart scenarios that connect multiple devices together. And if the power goes down, your eZLO hub will keep looking after your home thanks to the inbuilt battery.
eZLO Hub Using Z-Wave Protocol, eZLO is compatible with over 1700 (and growing!) smart living solutions helping you manage security, energy consumption, light, heating, HVAC, and more.
Check out the full listing of compatible devices for the eZLO Hub here. Full technical specifications for the eZLO Hub are included below.
Remote access
Real time monitoring
100% wireless
Advanced sharing
Automation rules
Connecting up to 255 devices
Compatible home automation devices
