Door / window sensor
Protect your home even when you are away
Many features in a single device
Tamper protection
–°ontact sensor
Immediate notification
Can be part of security system
*smart rules and sequences of actions require the eZLO hub to be set up
Simple Installation
1.
Download the application and set up your eZLO account
2.
Install both parts of the sensor to any window, door, or opening.
3.
Connect the door/window sensor to your Wi-Fi network via the application.
4.
Done! Now you can control your device with your eZLO app.
*for detailed step-by-step instructions see the manual
1. Download the application and set up your eZLO account
2. Install both parts of the sensor to any window, door, or opening.
3. Connect the door/window sensor to your Wi-Fi network via the application.
4. Done! Now you can control your device with your eZLO app.
Build an alarm system for your home
View the status of your door or window in the eZLO web or mobile app, set up notifications to know when your door is opened or closed, define rules involving multiple devices to make your home smarter
App notifications on tampering
App notifications on low battery
Z-Wave coverage: up to 30 meters
Over-the-air firmware updates
FCC, ETL and Z-Wave Plus certified
Z-Wave frequency
868.42MHz (Europe)
908.42MHz (US)
921.42MHz (Australia)
Size
Main body:
Height: 75 mm
Width: 28 mm
Depth: 18 mm
Magnet:
Height: 75 mm
Width: 12 mm
Depth: 18 mm
Power Supply
two AAA 1.5V Batteries (for up to 1 year of operation)
Longest effective distance
between the sensor body and the magnet: 10 mm
Working current
~60 mA
Standby current
~35 mA
