An outlet that you can also control
remotely
Why use smart switch
Power switch on/off
appliance
Real time energy
monitoring
Inbuilt surge and overcurrent protection
Monitoring power consumption
Left an iron plugged in? One tap and no need to get back home anymore, сheck if your device works right by analyzing how it consumes power, get notifications when some outlets work longer or consume more energy than usual.
*smart rules and sequences of actions require the eZLO hub to be set up
How It Works
1.
Download the application and set up your eZLO account.
2.
Plug the Plug in an electrical outlet.
3.
Connect the Plug to your Wi-Fi network via the application.
4.
Done! Now you can control your device with your eZLO app.
*for detailed step-by-step instructions see the manual
1. Download the application and set up your eZLO account
2. Plug the Plug in an electrical outlet.
3. Connect the Plug to your Wi-Fi network via the application.
4. Done! Now you can control your device with your eZLO app.
Enhance it with the eZLO app
You can use the eZLO hub to create smart rules and launch them with the
eZLO app:
A rule to switch off all your appliances before leaving for a vacation or business trip
A rule to launch all Christmas lights at the same time to surprise your kids
A rule defining the working schedule for electric devices of your choice
Color coded power usage
The crystal RGB LED ring inform you about the current load of the connected appliance visually by changing its color
Remote switching of electrical devices on and off
Two USB charging ports for mobile devices
Control of plugged-in appliances
Real time energy monitoring
Z-Wave coverage: up to 30 meters
Device
Z-Wave frequency
908.42MHz (US)
908.42MHz (US)
868.42MHz (US)
Size
Height: 84 mm
Width: 55 mm
Depth: 28 mm
Height: 100 mm
Width: 60 mm
Depth: 31 mm
Height: 115 mm
Width: 62 mm
Depth: 53 mm
AC output
120V / 15A (max)
120V / 15A (max)
230V / 10A (max)
USB output
5V / 1A
5V / 2.4A
5V / 1A
5V / 2.4A
5V / 1A
5V / 2.4A
LED
Indicates the off/on status
Shows one of eight colors depending on the amount of power consumed
Device
HKZW-SO01
HKZW-SO03
HKZW-SO05
Z-Wave frequency
908.42MHz (US)
Size
Height: 84 mm
Width: 55 mm
Depth: 28 mm
AC output
120V / 15A (max)
USB output
5V / 1A
5V / 2.4A
LED
