Forget remotes and manage IR-controlled devices via app
Convert Z-Wave signals from eZLO smart home hub into infrared signals.
AC units
Speakers
Bulbs
TV tuners
Players
Works seamlessly with IR-controlled AC units, light switches, bulbs, music players, speakers and other devices controlled with infrared remotes.
AC units
Speakers
Bulbs
TV tuners
Players
How It Works
1.
Connect the IR transceiver to your eZLO hub.
2.
Program the infrared code of your IR-controlled device into the transceiver.
3.
Done! Now you can control your device with your eZLO app.
1. Connect the IR transceiver to your eZLO hub.
2. Program the infrared code of your IR-controlled device into the transceiver.
3. Done! Now you can control your device with your eZLO app.
Usage scenarios
Having an AC unit controlled with a smartphone, you can cool your place BEFORE you arrive at home, not after.
With your smartphone always at hand, simply open the eZLO app and turn your stereo system on to listen to your favorite tune.
The TV your kids are watching in another room is too loud? Turn down the volume without shouting and asking them.
FCC, CE and Z-Wave Plus certified
IR coverage: up to 12 meters indoor
Over-the-air firmware updates
Z-Wave coverage: up to 40 meters
Cloud database of the infrared codes
Z-Wave frequency
868.42MHz (Europe)
908.42MHz (US)
921.42MHz (Australia)
Size
Height: 22 mm
Width: 85 mm
Depth: 85 mm
Powered by
5V/1A Micro USB Adapter
Working current
~60 mA
Standby current
~35 mA
Installation options
table and wall mounting
