Ezlo SoftHub + CCTV + AI Setup
Hardware requirements:
  • Softhub + CCTV with AI capabilities setup is currently only on amd64 windows and linux platforms.
  • Number of cameras a setup can support depends on multiple factors like
    • Camera resolutions
    • Features enabled (e.g., motion detection, sound detection, face recognition, QR code detection)
    • Amount of motion each camera sees
  • Recommended minimum hardware for 4 cameras :
    • Quad-core CPU
    • 8 GB Ram
    • 1 TB HDD (depends on recording needs)
Linux Installation
1. Get your Credentials
If you don’t have a MiOS account already, you can create a free account instantly through mios.com
2. Install Docker
Download Docker for your preferred OS at docker.com
3. Install Ezlo SoftHub
Once you have docker installed and ready you can downloadall images and provision your hub with a single command:
					docker run --net host -v /var/run/docker.sock:/var/run/docker.sock --restart=always --name orchestrator-vhubzz us-east4-docker.pkg.dev/softhub-354014/softhub/orchestrator:latest /root/orchestrator vhub -start -option provision -username=your-Ezlo-username -password=your-ezlo-password -zwave=/dev/ttyUSB1 -vidoo
Release Notes:
  • Change <your-Ezlo-username> and <your-ezlo-password> fields with the credentials you have on the MiOS platform.
  • CCTV + AI support enabled with version 0.7.3
  • To include CCTV + AI, the “-vidoo” parameter is required.
  • To enable Z-Wave support (via USB Z-Wave Stick), use this parameter: -zwave=/dev/ttyUSB1
  • If you do not have a USB stick, remove the parameter.
Windows Installation
2. Use Windows Installer
Download and run the Windows installer.
Access Your Ezlo SoftHub
Download our Mobile App on Your Device if you haven’t done already.
Getting Started
Visit http://localhost or http://[ip-address-of-remote-computer] in your browser to begin the setup process.
You’ll see two options. If this is a new installation, click “Create a new Vidoo.”
Login
You will see login page. Enter your MiOS credentials to add your new SoftHub to your account.
If you do not already have an account, click the “Signup” button.
Finish Setup
Click “Setup” to finalize your SoftHub instance.
You’re ready to go!
You can now use CCTV + AI capabilities through the web interface at http://localhost or http://[ip-address-of-remote-computer].
Click here for detailed instructions for using the Vidoo interface.
Need additional help?
From initial setup to expanding your system, Ezlo will help every step of the way.
Tell us about your device
Soultions
Products
Ezlo PlugHub
Ezlo Plus
Ezlo Secure
InstaVue Cameras
Security Sensors
Water Shut Off Valve
Climate Control
Lighting
Secure Essentials
Secure Essentials+
Secure Environmental
Secure Video
Products
Solutions
Support
Explore
MiOS Login
For Ezlo Protect
For Distributors
For Ezlo Partners
Products
Smart Homes Hub
Ezlo PlugHub
Ezlo Plus
Ezlo Secure
Security Addons
InstaVue Cameras
Security Sensors
Accessories
Climate Control
Lighting
Kits
Secure Essentials
Secure Essentials+
Secure Video
Ezlo PlugHub
Ezlo Plus
Ezlo Secure
InstaVue Cameras
Security Sensors
Climate Control
Lighting
Secure Essentials
Secure Essentials+
Secure Video
chatsimple
