This article will demonstrate how easy it is for you to pair a Fibaro Dimmer with Ezlo Hubs.
Pairing
First, set up the dimmer and the dimmer lamp close to the controller.
Go to the Vera app, click the menu icon, and navigate to “Devices.”
Next, tap the “+” symbol, and select “Dimmers and Lights.”
Select “Add New Device.”
Find Fibaro Dimmer 2 FGD-212 v3.5 and click on it.
When the Fibaro Dimmer is ready for pairing, tap “Next” to initiate the pairing process.
Press the reset button with a small screwdriver or pin to activate pairing mode on your Dimmer.
Next, wait for the controller to identify and pair with it.
When prompted, confirm the pairing.
You are all set to go; congratulations.
Dimmer
You can now use your app to control the dimmer and set scenes on varying light intensities.
You can use the Vera app to turn on or dim lights remotely.
Unpairing
Go to the app and hit the “Unpair” button at the top right corner next to the “+” sign to unpair the devices.
Next, use a screwdriver or pin to press the reset button twice.
Go to the app and confirm your action.
